Gear oil is one of those subjects that splits the room. Half the people in any enthusiast forum will swear their box has been running the same fill since the factory. The other half have stripped a gearbox and found synchro rings that look like they’ve been sandblasted. I’ve been in both camps at different points, and I can tell you from experience: the lubricant in your manual gearbox is doing far more work than most owners realise, and getting it wrong has a cost that tends to arrive with a horrible crunch somewhere between third and fourth on a cold morning. This performance gearbox gear oil UK guide is my attempt to cut through the noise.
Why gear oil is nothing like engine oil
Engine oil gets changed every year and everyone understands roughly why. Gear oil? People run it for a decade and assume it’s fine because they can’t hear anything grinding. The chemistry is completely different. Gear oil carries an extreme pressure (EP) additive package designed to handle the metal-to-metal sliding loads inside a helical gearbox under load. Engine oil does not. If you’ve ever seen someone top up a gearbox with engine oil because “it was the only thing in the garage”, that is a genuine horror story. The EP additives specifically protect synchro rings and gear faces under shear loads that would destroy a standard engine oil film in seconds.
The viscosity rating system is also its own world. You’ll see designations like 75W-90, 75W-80, 80W-90, and occasionally something like MTF-94 or LT71141. These SAE viscosity grades describe how thick the oil is at cold start (the first number) and at operating temperature. A 75W-90 is thicker at temperature than a 75W-80. That matters enormously for synchro function, especially on a cold box in February in the north of England.
GL ratings: what GL-4 and GL-5 actually mean for your synchros
This is where a lot of people go wrong. GL-5 sounds better than GL-4. More number equals more good, right? Not for most performance gearboxes used on UK roads. GL-5 oils carry a heavier sulphur-phosphorus EP additive load, which is designed to protect hypoid rear axle gears running under high shock loads. The problem is that those same additives are chemically aggressive to the yellow-metal alloys used in synchro rings and brass shift forks, which are common in many European and Japanese gearboxes. Run GL-5 in a box that specifies GL-4 and you can chemically erode your synchros over time. You won’t notice it immediately. You’ll notice it when third gear starts to baulk on a cold morning and then, a few months later, crunches going in hard.
Common UK performance cars with strict GL-4 specifications include the Mk5 and Mk6 Volkswagen Golf GTI (the 02Q and 0A5 boxes), the Honda Civic Type R (K20 era and FK8), and most Renault Sport applications including the Mégane RS. The BMW manual boxes (Getrag units) used in the E46 M3, E90/E92 era M3, and the Z4 M Coupe are particularly sensitive and typically spec a proprietary Castrol or ZF fluid. Getting that wrong is an expensive mistake. The independent specialists who actually know these cars will not touch them with anything other than the correct spec, and for good reason.
OEM specifications and why they matter more than the GL number
Modern gearboxes have moved well beyond simple GL ratings. VW Group specifies G 052 171 for many manual applications. BMW had its own Castrol-derived MTF-LT-5 spec, now often replaced with ZF LifeGuardFluid 8 derivatives. Renault Sport boxes in the RS225 and RS265 Mégane originally called for Elf Tranself NFJ, a synthetic 75W-80 GL-4. Mitsubishi Evo gearboxes have their own spec. Ford’s Mountune-supported Focus ST and RS boxes each have different requirements. The OEM spec number is more useful than the GL rating because it defines the full additive chemistry, not just the load-carrying classification.
Where do you find OEM specs? Your vehicle handbook is the first stop. Failing that, the factory workshop manual, which you can often find via ALLDATA or ETOS subscriptions, or for many European cars via ETKA and equivalent parts databases. For Japanese imports, the original service schedule PDF is usually your best friend. The DVLA classifies the car by its original spec, but the fluid requirements came from the manufacturer, so always cross-reference with the original documentation rather than relying on a generic application guide from the shelf at Halfords.
What cheap gear oil actually does to your synchros
I’ve had the misfortune of seeing this up close. A mate bought a 2005 Subaru Impreza WRX STI that had been filled with a generic 80W-90 mineral GL-5 by the previous owner, presumably because it was cheap and the colour looked right. The synchro rings in second and third were almost completely glazed when the box came apart. The friction characteristics of a synchro ring depend heavily on the lubricant it’s running in; mineral GL-5 in a box that needs a synthetic 75W-90 GL-4 changes the friction coefficient at the cone face, meaning the synchronisation phase is either too slow (causing missed shifts) or inconsistent (causing crunch under pressure). Combined with the sulphur-phosphorus attack on the brass alloy, you get accelerated wear that compounds over every cold start and hard gear change.
Cheap oil also degrades faster. Mineral gear oils lose their viscosity index improver package more quickly under shear stress, meaning that 80W-90 mineral oil in your Evo box is probably sitting closer to a 40-weight fluid after 30,000 miles of use. Full synthetic fluids hold their viscosity range far longer and carry a more stable additive package. For a performance car that’s driven hard, there’s simply no sensible argument for going budget on gearbox lubricant. The saving is maybe £20. A rebuilt gearbox is closer to £1,500 to £3,000 depending on the application.
When to change it and how often
Most manufacturers who actually specify a change interval suggest somewhere between 40,000 and 60,000 miles for normal use. For performance driving, particularly track use, I’d recommend halving that. Heat is the enemy of gear oil stability, and a box that’s been worked hard on a track day will have seen temperatures that age the fluid significantly. If you’re running your car on circuit at all, you should be treating gearbox oil as a regular service item on the same cadence as your brake fluid. The additional stress from remapped engines also puts greater torque loads through the box, making fluid condition even more critical.
The colour and smell test is a rough guide at best. Fresh gear oil is typically amber to yellow. Old, degraded gear oil goes dark brown to black and carries a distinctive burnt sulphur smell. Metal particles in the oil show up as a metallic sheen; if you drain your gearbox and the oil looks like it has glitter in it, that is shavings from gear faces or synchros and you have a bigger problem than a fluid change will fix. For anything with a drain plug, I’d say pull it every two years regardless of mileage if the car is used hard. It’s a 30-minute job and the cost of two litres of correct fluid is trivial against what you’re protecting.
Trusted brands and what UK specialists actually reach for
The brands I see consistently recommended by the specialists who know these gearboxes are Motul, Redline, Castrol (specifically their OEM-spec variants), and Millers Oils, which is a Yorkshire-based manufacturer with a strong reputation in the UK motorsport and enthusiast community. Millers’ CRX range covers GL-4, GL-5, and mixed applications and is used by a number of UK racing outfits. Redline MT-90 is particularly well regarded for Mitsubishi and Subaru applications. Motul Gear 300 (75W-90 full synthetic, GL-4/GL-5 compatible) has a devoted following among Honda and Renault Sport owners.
Worth checking is whether the fluid you’re buying claims both GL-4 and GL-5 compatibility on the same bottle. Some modern synthetics manage this through a different additive approach that’s less aggressive to yellow metals whilst still providing the EP protection. It’s not universal, so check specific compatibility notes from the manufacturer before assuming a dual-rated oil is safe for your particular box. Using the wrong spec fluid can also create complications if a gearbox-related issue is ever presented as a warranty or insurance matter. You want a paper trail showing correct maintenance to spec.
For those running grey import performance cars with JDM gearboxes, getting the correct OEM spec can be trickier. Japanese Domestic Market applications sometimes used proprietary fluids that aren’t directly sold in the UK. In those cases, cross-referencing with the manufacturer’s global service data and matching a trusted synthetic to the viscosity and GL rating is the pragmatic route. The Motor Ombudsman’s approved garage standards include correct fluid specification as part of the service quality framework, which gives you a benchmark for what a reputable workshop should be doing.
Get the spec right, change it on time, and a quality performance gearbox will reward you with crisp shifts for well over 100,000 miles. Get it wrong and you’ll know about it eventually, always at the worst possible moment.
What gear oil should I use for a VW Golf GTI manual gearbox?
The Mk5 and Mk6 Golf GTI 6-speed manual (02Q box) specifies VW G 052 171 A2 fluid, which is a synthetic 75W-90 GL-4. Approved equivalents include Castrol Syntrans Multivehicle 75W-90 and Motul Gear 300. Avoid GL-5 oils as they can damage the brass synchro rings over time.
How often should I change gear oil in a performance car used on track?
For road use only, most manufacturers suggest 40,000 to 60,000 miles or every three to four years. If you’re doing any track days, change it every 15,000 to 20,000 miles or annually, whichever comes first. Heat from circuit use degrades the additive package significantly faster than normal road driving.
Can I use GL-5 gear oil in a car that specifies GL-4?
Generally no, and this is a common and costly mistake. GL-5 contains higher concentrations of sulphur-phosphorus EP additives that are chemically aggressive to yellow-metal alloys used in many synchro rings and brass shift forks. Over time this accelerates synchro wear noticeably. Unless the manufacturer explicitly approves GL-5, stick to GL-4 as specified.
What is the difference between 75W-80 and 75W-90 gear oil for a manual gearbox?
Both have similar cold-start viscosity but the 75W-90 is thicker at operating temperature. Thicker oil can slow synchro engagement slightly, which is why some manufacturers specify 75W-80 for better shift quality on road-focused performance cars. Always follow the OEM specification rather than using a heavier grade on the assumption it provides better protection.
