What Britain’s Crumbling Road Surface Is Actually Doing to Your Suspension and Tyres
Simon McWilkins avatar
British roads are in a bad way. The RAC’s 2025 Pothole Index recorded pothole-related breakdowns at their highest level in years, and if you’re running a lowered or performance-tuned car, you’re feeling every single one of them. Cracked sidewalls, blown dampers, bent wishbones, UK road surface suspension damage on performance cars has quietly become one of the most expensive and least-talked-about running costs in the scene. This isn’t a whinge about council budgets. It’s a practical breakdown of what’s actually happening to your car and what you can do about it.
Why performance cars suffer more than standard road cars
A standard family hatchback on 55-profile tyres with 160mm of suspension travel will soak up a pothole that your coilover-equipped track-focused build simply cannot absorb. That’s the physics. Lower ride height reduces the available suspension travel before the wheel hits the bump stop. Stiffer spring rates transfer more impact load directly into the tyre and wheel rather than dissipating it through controlled compression. Run a 40-profile tyre on a 19-inch wheel and there is almost no sidewall left to act as a buffer. The tyre’s job shifts entirely to the tyre carcass and the rim, neither of which is designed to cope with the kind of 150mm-deep potholes now common on rural A-roads and suburban B-roads across the UK.
The damage compounds quickly. A single heavy hit can crack a tyre’s internal structure without any visible external damage, what’s known as a sidewall impact fracture or internal delamination. The tyre looks fine. Then it fails at 70mph on the M6. Beyond the tyre, the same impact loads the lower control arm, wheel bearing, and damper rod simultaneously. Run it over a few times and you’re looking at accelerated wear on bushes, premature bearing failure, and damper seals that start weeping oil long before their design life is up.
Choosing tyre sidewalls for UK road conditions
Profile selection is genuinely one of the most important decisions a UK performance car owner makes, and it’s one that doesn’t get discussed enough. The obsession with giant alloys and ultra-low profiles looks great in a car park. On the A9 north of Perth or the B4293 through the Wye Valley, it’s actively expensive.
If your build is a dual-purpose setup, fast road and occasional track, seriously consider dropping a wheel size and running a taller profile. Going from a 19-inch to an 18-inch wheel on the same car often lets you run a 45 or even a 50 profile, which makes a significant difference in real-world compliance without compromising handling materially. Michelin’s Pilot Sport 4 and Continental’s SportContact 7 both perform well in these applications and are available in sizes that work for most coilover setups.
For the tyre itself, look at reinforced sidewall construction (sometimes labelled XL or Extra Load). These have stiffer carcasses that resist pinch-flat damage better when you clip a pothole edge. They’re not a cure, but they add a meaningful margin on UK road surfaces that standard-load tyres don’t provide.
Damper longevity on terrible tarmac
Coilovers are not maintenance-free. Most owners treat them as fit-and-forget, which works fine in countries with decent road surfaces. In the UK, the story is different. A quality coilover on a UK performance car driven regularly on public roads should realistically be rebuilt or replaced every 40,000 to 60,000 miles if you’re using the car hard. Budget-end coilovers from less reputable brands often need attention sooner, particularly the damper seals which are the first thing to go when the unit takes repeated heavy impacts.
The tell-tale signs: a knocking or clunking from the front end over sharp bumps, the car feeling vague or floaty over undulations, and visible oil seeping down the damper body. If you’re seeing any of those, the unit is already compromised. A seized or oil-starved damper transfers load directly to the spring perch, the top mount, and the subframe, at which point you’ve got a much bigger bill coming.
Brands like Bilstein, KW, and Öhlins build for longevity and offer rebuild services in the UK. If you’re putting serious mileage on the car, factor a damper rebuild into your annual maintenance budget. It’s cheaper than a new set, and a freshly rebuilt unit performs identically to new.
Which aftermarket suspension setups cope best with UK roads
Full coilover kits with separate spring and damper adjustment give you the most flexibility to tune compliance. A softer spring rate with a firmer rebound setting can give you flat cornering on smooth stretches without punishing you on the rough stuff. That said, the spring rate needs to be appropriate for your car’s weight and geometry, go too soft and you introduce excessive body roll and bottom out on large compressions.
For daily-driven performance cars, many experienced builders have moved back towards quality OEM-plus dampers, think Bilstein B6 or B8, paired with a mild drop spring. You sacrifice the ultimate adjustability but gain genuine day-to-day usability and better longevity on variable UK surfaces. If you’re building a track-only car that gets trailered to circuits, go full stiff coilover and don’t worry about it. If the car sees school runs and Saturday blasts equally, the extreme-stiffness coilover is working against you most of the week.
The hidden costs of building and running a modified car go well beyond the parts themselves, if you haven’t read through our piece on the real hidden costs of running a modified car in 2026, that’s worth twenty minutes of your time before you pull out a card.
Making a pothole damage claim against your local council
This is the part most people don’t bother with, and they’re leaving real money on the table. UK local councils have a duty under the Highways Act 1980 to maintain public roads to a safe standard. If a pothole caused your damage and the council had been notified of it previously (or should have spotted it during routine inspection), you have a legitimate claim.
The process is straightforward but requires evidence. Photograph the pothole immediately, include a ruler or coin for scale, and capture the surrounding road surface. Get the exact location: street name, postcode, nearest landmark. Note the date and time. Then photograph the damage to your vehicle before anything is touched. Get a written assessment from a tyre or suspension specialist confirming the cause. Keep every receipt.
Submit your claim directly to the relevant local authority’s highways department. Most councils now have an online claim portal. The gov.uk pothole reporting tool can direct you to the correct authority. Councils frequently reject first claims on the basis that they weren’t previously aware of the defect, this is the “section 58 defence”. If rejected, appeal with evidence of how long the pothole had been present, using services like Google Street View historical imagery or FixMyStreet reports.
Success rates vary but they’re not negligible. A well-documented claim for a blown tyre and damaged rim has a reasonable chance of recovery. Don’t skip the process just because it feels bureaucratic.
Track day prep starts on the road
If your car is headed for a circuit, the state of your suspension matters even more. Worn or damaged dampers that feel acceptable on the road will feel vague and unpredictable at speed. Check your geometry after any serious pothole impact, a hit hard enough to crack a tyre is hard enough to knock your alignment out. A corner-weighting and geometry check before a track day isn’t just performance optimisation, it’s safety-critical.
Our guide on building a budget track day car in 2026 covers suspension setup in the context of getting a car circuit-ready on a realistic spend, which pairs well with thinking about how your road driving affects the setup. And if your brake fluid hasn’t been changed recently, the same logic applies, UK roads with their variable temperatures and repeated heavy braking cycles degrade fluid faster than you’d expect, so it’s worth reading up on brake fluid grades for fast road and track use while you’re reviewing the car’s condition.
British roads aren’t getting better anytime soon. Budget accordingly, specify your tyres carefully, service your dampers before they fail, and claim when the council’s negligence costs you money. That’s the reality of running a performance car in 2026.
More from the scene
