Induction maestros Pipercross have released details of their latest range of competition-spec filters.
The hugely diverse range has been designed to offer a variety of solutions for race teams, car preparation outfits and specialist car builders. Over 40 different combinations of neck and filter diameter are available ranging from 50 – 146mm necks with a choice of 5 filter sizes from 100 to 300mm.
Not only are the range of sizes vast, to accommodate almost every possible application, space or airflow, but also cover varying construction types including foam top, alloy caged and straight walled. All use a precision moulded rubber neck to allow for quick and easy fitment to any circular mating surface. Best of all, they’re all made entirely here in the UK.
As well as increased flow characteristics, all Pipercross filters can actually filter down to a much finer rate than factory filters, preventing any foreign particles from harming the engine, extending its serviceable life. This same construction means that the filter can also go longer between service intervals than even leading cotton-gauze filters, before needing to be cleaned.
Despite these impressive abilities, all Pipercross filters come with a lifetime warranty and can be easily cleaned again and again for re-use, providing decades of faithful service and paying for themselves many times over – and that’s before you start factoring in the significant performance benefits.
Perfect as an upgrade for an existing induction kit, or for those looking for a bespoke solution. Basically, if you need a specialist filter – this range should cover it. Prices start at just £27.99 and rise to £56.99.
For more details on the 3000 vehicles covered by the Pipercross range, please visit www.pipercross.com or call the team on 01604 707750.
