It’s a product that does exactly what it says on the label, the Meguiar’s Ultimate All Wheel Cleaner is all the wheel cleaner you need…
This is one of those products that’s universally loved by all car care fanatics across the globe, and its Ronseal name gives a massive clue why. That’s right, this powerful Meguiar’s Ultimate All Wheel Cleaner also has a gentle side, as its acid-free and pH balanced formula is safe to use on all wheel finishes. Meaning that those expensive 3-piece split rims you re-mortgaged your house for won’t be damaged while it gets to work turning brake dust purple and road grime brown as it gently loosens stubborn contaminants from your rims. A must have for any detailer’s kit bag.
How to use:
It couldn’t be simpler. Spray directly onto your wheels, you don’t have to wet them first, nor do you need to agitate it.
Wait 1-2 minutes for it to work its magic, you’ll see it working when it starts to turn purple. Then rinse it off with a jet wash. Voila.
One thing we will say is that while the product is damage free, don’t leave the product on too long or you can risk some light staining that requires wiping off.
Ultimate Wheel Cleaner – £17.99 – shop
