LIBERTY WALK TOYOTA SUPRA A90
Well, it was only a matter of time wasn’t it? We’ve been waiting patiently for the Liberty Walk Toyota Supra A90, and now it’s here.
Arguably the crown jewels in wide-body conversion kits, once occupied by the likes of Dimma, Liberty Walk has revealed renders and an almost complete build of its new body kit for the Toyota Supra A90. Divisive the car may be, this looks cool!
Liberty Walk Toyota SupraLiberty Walk Toyota Supra
What have we got then? The obvious place to start is at the rear with its huge wing; here it’s supported with a beam during the final stages of the build. The rear arches are wide enough to look at home on an RWB Porsche, the rear diffuser would look at home on a GT3 racer and those extended side skirts help give it a “ground effect” look. The front arches are naturally widened and the front gets a splitter sat on the ground. Included in the most expensive package is a new vented bonnet as well.
There are two options you can go for: the first, which is cheaper at around $14,850 comes without the vented bonnet and is finished in Fibre Reinforced Plastic (FRP). The more expensive package, at $19,030 comes with the vented bonnet and the whole kit is finished in Carbon Fibre Reinforced Plastic (CFRP). This is all non-painted, so you’d have to factor that in, as well as some wide-ass wheels to fill those extended arches.
Check out Toyota’s own Supra build!
